pg 10 test c3220
  • pc123321
    • Dec 2012
    • 103
    pg 10 test c3220
    this is c3220 pg10 test
    any advice are welcome
    thanks
  • teckat
    • 16083
    Re: pg 10 test c3220
    thanks
    build up of toner on underside of ITB PLATE drags on ITB sheet>causes streaks
    remove the ITB>next remove the metal underside plates>turn them over to clean underside>
    now take that large plate and throw it in the garbage can >put back the small plate & make sure to screw attach (1) back into plate / & wedge (2) other end of varistor under the spring leaf (no area to screw in) ( so u don't receive a sporadic error code)--
    • pc123321
      • Dec 2012
      • 103
      thanks
      after clean ibt belt then it working
      after that the pg 10 test shown
      • teckat
        • 16083
        your BLACK is now a mess/ ??
        did u remove ITB BELT or just clean outside of it & plates ?
        • pc123321
          • Dec 2012
          • 103
          developer ?
          itb belt take out the belt and clean 4 roller
          • teckat
            • 16083
            developer ?
            u need to remove ITB & ITB BELT to inspect the Primary Transfer Roller for BLACK> Inspect it's position on both sides> make sure it is pushed into the end spring loaded holders & rotates freely
            BLACK LOOKED OK on your first PG10 before u cleaned ITB// what did u use to wipe the rollers with
