Can you collate on a Canon IR1023iF???
  • Morales3556
    • Apr 2011
    • 14
    theres a collate button on the printer,when i turned it on, it doesnt collate i just want to
    be sure if this machine even collates.any information would be greatly appreciated.
  • northernlife
    • Sep 2011
    • 847
    Re: Can you collate on a Canon IR1023iF???
    It does for print jobs/df fed jobs. If not perform an all clear and/or system upgrade.
    • teckat
      • 16092
      COPY SETTINGS>STANDARD SETTINGS>AUTO COLLATE: OFF(*), COLLATE
      Sets whether to collate the copies automatically.
      – OFF
      – COLLATE
      PRINTER SETTINGS
      >COLLATE OFF(*), COLLATE
      Sets whether to collate the printouts automatically.
      – OFF
      – COLLATE
      *: indicates factory settings is set off /
      check settings >
      Collate Copy
      You can copy documents collated into sets arranged in page order. This feature can be used together with both “Two-Sided Copying” and “2 on 1 Combination”.
      1. Set documents.
      Place the first page on the platen glass if you are not using the ADF.
      2. Press [COPY].
      NOTE
      If <AUTO COLLATE> is set to <COLLATE> in <STANDARD SETTINGS> in <COPY SETTINGS>, skip step 3 and 4.
      3. Press [Collate].
      <COLLATE> appears in the LCD.
      4. Press [ ] or [ ] to select <ON>, then press [OK].
      5. Use the numeric keys to enter the desired copy quantity (1 to 99).
      6. Press [Start].
      When the documents are loaded in the ADF, collate copying starts and no further operation is required.
      If the document is placed on the platen glass and <ORIGINAL SIZE> is displayed in the LCD, press [<-] or [+>] to select the original size, then press [OK].
      7. Place the next page of the document on the platen glass, then press [Start].
      Repeat this step to scan all pages. The machine prints only one copy of each page.
      8. Press [OK].
      – The machine prints the remaining sets of copies.
      – To cancel all settings, press [Reset].
      NOTE
      When scanning multiple page documents, <MEMORY FULL> may appear in the LCD and scanning may be canceled. If this happens, press [Stop] to return to the standby mode.
