Canon imagepress c1 err fuser, please help!
  • mrban
    • Sep 2012
    • 25
    Canon imagepress c1 err fuser, please help me! i was check fuser hot roller and belt ok.
    • 16083
    Re: Canon imagepress c1 err fuser, please help!
    so what's the issue ?? ink smear ?
    last time u rebuilt fix unit
    what type of paper using ?
    how are text only docs ?
    • mrban
      • Sep 2012
      • 25
      wrinkled paper, i use fort paper 80gsm, same problem with text only docs
        • 16083
        is it on long sheet>trail edge only ?
        Wrinkles appear only on the last 6 inches of 11x17 paper all other paper sizes are wrinkle free.
        Stop the paper in the fixing unit to see if it is wrinkling after fixing or before.
        Replace Secondary Transfer Mount Assembly (FM2-2485-010) it should resolved the wrinkling problem on the trail edge of 11x17 stock.
        is it on short sheets
        or>>>>>>>>>>>>>>>>>>>
        Replaced the Lower Fixing Belt Assembly (FM2-2480-000). When rebuilding the Lower Fixing Belt Assembly ensure you do not remove or throw away the black spacer under the pressure pad. The black spacer can stick to the pressure pad and be discarded during service.
        • mrban
          • Sep 2012
          • 25
          Wrinkled paper on large size , i print A4 no problem. Thanks your help! i will check my printer again .
            • 16083
            _____
            I would go change that lower fix belt unit
            • mrban
              • Sep 2012
              • 25
              Can you show me the online shop to order canon imagepress part? Thanks you!
              • Joseph2011
                • Aug 2011
                • 88
                good morning
                this paper wrinkle problem is due to several factors:
                1 -. Fixing Belt (FL2-6530-000) with too much use
                2 - Pressure Pad Assembly (FM3-1217-000)
                3 -. Speaker spent fixing roller
                review and let me know
