This machine sometimes does not go back to AUTO. Will sometimes report " Load Paper or check settings the most proper size STMTR is not avaiable. This happens after making a copy sometimes. Open and close feeder.
Next symptom: Lay LTRR on the glass. Machine will not see it as LTRR, reports LTR! Ran adjust function in feeder again. Looks like the length sensor and length sensor harness needs replaced. Would not think anything else could cause this...
LTR copy has turned into 11 x 17 output on a couple occasions.
