Canon IR2800 Format the hard drive.
  • yormets
    • May 2009
    • 336
    I can't recall the method to format the hard drive on this box. Can someone please tell me. Turn on and hold something down I think. * 8 maybe?
  • tykesupport
    • May 2014
    • 24
    Re: Canon IR2800 Format the hard drive.
    To format and flash the machine you Service Support Tool, SST. You can go into service mode *28* COPIER>FUNCTION>SYSTEM>CHK-TYPE and clear HDD partitions.
    • yormets
      • May 2009
      • 336
      That's not it. The display creates blocks as it formats.
      • teckat
        • 16083
        -Hold down the 1 & 9 keys while turning the main power switch on and let the machine go through a disk defrag (should take about half an hour).
        power off printer>hold down 1 & 9 key > while holding >power back up> hold keys until white blocks start dropping
        works sometimes> if not u get a NG > time to replace HD
        • yormets
          • May 2009
          • 336
          Thank you. That's what I was looking for.
