iR7095-V2 poor quality
  • aco.bk
    • Sep 2012
    • 130
    HI,
    I have iR 7095 V2 with poor image quality.I m already replace potential sensor,AP kit Assy,DC Power supply assy,develop unit,primary & transfer corona,updated system software but print/copy is still bad.there is scaned P Print in atach .pls giveme some advice to resolve this problem.Counter 102 is 293590.
    ty
  • V-P
    • Apr 2011
    • 679
    Re: iR7095-V2 poor quality
    VL1T & VL1M are far from each other.
    Check Laser.
    • teckat
      • 16083
      Originally posted by aco.bk
      HI,
      ty
      Have Copies and Prints been made with Potential control off to check the copy quality.
      Do a panic stop and check the image on the drum
      Laser Dust Proof Glass remove>Check>Clean It-
      CHECK DRUM SURFACE POTENTIALS
      The measured and target values (VL1M and VL1T) (VDM and VDT) in DPOT, SERVICE MODE>COPIER>DPOT, should be relatively close in value.
      When the measured value of VDM (VOLTAGE DRUM/DARK) is close to the value of VL1M (VOLTAGE LIGHT) the SCANNER LASER AND BLANK LAMPS should be investigated because the primary voltage is not being dissipated by light.
      Check visually to make sure that blanking lamps are coming on. You should see a red glow next to primary corona, and don't forget to cheat the laser shutter when looking or else it will generate an E110
      Replace LED ARRAY Unit if needed. = FH7-3395-020
      Check the the laser shutter. When the shutter is not open fully, the VL1 value will rise. Bent actuator may be the cause.
      Replace the Laser Unit. The part number for the Laser Scanner Assembly is FM2-5449-010.
      CHECK DEVELOPER
      If copies and prints are light, check the coating of Toner on the Developer.
      • Rachid.Akli
        • Oct 2011
        • 595
        Check Laser.
        YES, this issue is common in this series. Replace the laser diode. It is available as a separate part: FM2-8146-000000.
        Rachid.
        "Find a job you love and you’ll never have to work a day in your life." Nagy's father
        • aco.bk
          • Sep 2012
          • 130
          thank You ,I will replace laser and inform You about changes .
          • zoraldinho
            teacher-guide-expert-guru
            • Mar 2008
            • 5015
            Hi Aco
            First check image on drum before swaping laser.
            • teckat
              • 16083
              did u do some troubleshooting > best not to take a shotgun approach
              • Herrmann
                • Jan 2006
                • 792
                The laser assy is expensive, so first at all, i would try to clean all laser mirrors including the polygon mirror thoruoghly and see, if things change. You have nothing to loose, so give it a try.
                If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
                • Canuck
                  Tech Specialist
                  • 1713
                  VLM way out as mentioned...laser not discharging drum during potential control. Nothing to do with development, and VD is right on spec. Drum being charged but not dischaged by laser. Changed many Laser Diode PCBs on these models. Simple to get at and replace. Could be dirty but with readings that out of whack it probably needs the part...FM2-8146
                  • aco.bk
                    • Sep 2012
                    • 130
                    Because of floods in my country, I am unable to do some troubleshooting or give You answers about laser.I will inform You as soon as possible..
                    • aco.bk
                      • Sep 2012
                      • 130
                      Laser Assembly replaced and print/copy are perfect.Thank You all again.
