Black lines when scanning IRC2380
  • jrgf67
    • Feb 2010
    • 37
    Greetings. I have a problem on a IRC2380 only happens when scanning and leaving some black lines when sending both the RDF and the glass table. What can be the problem?. thanks
    • 16083
    Re: Black lines when scanning IRC2380
    was that a blank sheet u scanned of glass
    Has the Scanner Area, White Plate, Glass, CIS and Laser Slit Glass been inspected & were all cleaned.
    • jrgf67
      • Feb 2010
      • 37
      • Herrmann
        • Jan 2006
        • 792
        had this problem here also, open the controller box, remove the memory, clean the contacts thoroughly and reseat, did the trick for me.
        If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
        • hotsun
          • Dec 2013
          • 12
          If the problem occur when you scan files, it will be that there is something wrong with the scan components. It means that the scan components need to be cleaned or maintenance. If you meet the problem when printing, there is something wrong with the drum unit.
          • Nutstar
            • Mar 2011
            • 110
            ensure scan area is clean (slit glass and platern)
            clean CIS and mirrors with a soft cloth
            reseat memory chips
            replaced CIS
              • 16083
              -_-_-
              All images result from the Drum > Scans, Copies, Prints >
              Poster said only from Scans = U start from the basic learning curve of Copier Process>
              On Scans or Glass operation > OPTICS > EXPOSURE > IMAGE CONVERSION
              • jrgf67
                • Feb 2010
                • 37
                Saludos. Gracias por contestar, en cuanto vuelva a la maquina compruebo lo que me habeis comentado.
                Greetings. Thanks for answering, as I check the machine again what you have told me.
