Change counter
  • raztech
    • Dec 2008
    • 88
    Change counter
  • zoraldinho
    teacher-guide-expert-guru
    • Mar 2008
    • 5013
    Re: Change counter
    Not posible.
    • canonbundy
      • Jun 2012
      • 607
      Re: Change counter
      and illegal
      • teckat
        • 16083
        Re: Change counter
        Originally posted by zoraldinho
        Not posible.
        It is illegal to tamper with this circuit in an attempt to falsify the counter readings of any Canon
        Copier.
        Not sure if this series has a Counter Memory PCB installed ?/
        Usually> The Serial Number PCB is a matched board with the Counter Memory PCB and cannot be swapped
        with any other equipment. Doing so will generate an E354 or E355 code.
        Don't believe u can change the Internal Counter for TOTALS>in Service Mode
        Total Counters
        TTL = Total counter
        COPY = Total copy counter
        PDL-PRT = PDL print counter
        REP-PRT = Report print counter
        2-SIDE = Double-sided copy/print counter
        SCAN = Scan counter
        But I believe u can change the External Physical Counter Unit on this series models may be legal on this series
        FM4-0646-000
