IRA 2535
  • vamoursly
    • Sep 2011
    • 273
    IRA 2535
    Hello
    I have been told that this machine is producing light copies, I will test printing when I go onsite later via USB; the drum and developer is with life.
    My first thought is toner deposit on the laser glass.
    I have been looking through the SM and removing the laser scanner unit, so I can clean it effectively
    Can this be done without removing the laser completely from the body, just interested to see if anyone has done this.
    Cheers
    V
  • vamoursly
    • Sep 2011
    • 273
    Re: IRA 2535
    I took it apart and gave it a thorough clean including cis
    I checked the laser unit could not see any toner residue, I changed the developer and ran a few hundred copies through until toner was at the correct density.
    I am experiencing something odd, on copies the quality and density is were I would expect it to be, but on prints via usb and ufr there is a wash type effect on the bottom of the page.
    I changed the developer according to the SM, but I did not see any further configuration requirements.
    Can anyone verify if there are any further actions required post Dev swap out?
    Cheers
    v
    • vamoursly
      • Sep 2011
      • 273
      Re: IRA 2535
      Sorry I might have mislead the copier type, it's a mono machine
      • teckat
        • 16083
        Re: IRA 2535
        OK u meant a iR2535
        did u check the Transfer Roller ???
        Make sure the contact on the HVT is stuck out of position causing the light images. Reposition the contact. Please see the photo below for the location of the contact.
        • Canuck
          Tech Specialist
          • 1713
          Re: IRA 2535
          Yes I have also had transfer roll pop out on door.....light images
          • livancicm
            • Sep 2008
            • 96
            Re: IRA 2535
            Clean the laser unit.
            • vamoursly
              • Sep 2011
              • 273
              Re: IRA 2535
              I inspected the laser as previous post suggests, I am going to change the secondary transfer roller, I think it has lost efficiency
              v
