IAC 7055 messed up from power surge
  • sharptech1
    • Oct 2011
    • 163
    problem started with e280 error. replaced reader controller pcb. got rid of error code. pg 10 test print showed up washed out on all colors and with cyan and magenta absent on non operator side. inspected magenta developer unit to find missing on mag roller. reinstalled magenta dv and got e75. adjusted transfer belt but print is still light. tried dcon clear with backup and restore. thinking dc controller or hvt pcb. any thoughts and ideas are appreciated.
  • sharptech1
    • Oct 2011
    • 163
    Re: IAC 7055 messed up from power surge
    uploaded pg 10 test print to help little hard to see tho
    • vigour
      • Aug 2010
      • 1038
      Did you re-install the RCON values?
      • sharptech1
        • Oct 2011
        • 163
        would rcon values affect internal print
        • vigour
          • Aug 2010
          • 1038
          Not likely, but after you fix it you will end up with other problems when you scan/copy.
          I am taking you through the process.-----Always input the values after a clear
          Quick answer to your problem.
          Do autograd with Hammermill or equivalent good paper AFTER correcting the RCON values
