Im constantly getting the error code of E732-0001 which i know is communication i have already disconnected all and reconnected all the cables
on the main controller pcb2 and the reader controller pcb also the scanner powers on and works fine i had sent off the main controller pcb 2 to a company that testes the pcb and they said it was fine it came back and still does the same thing.Also sometimes in service the rcon would not show up and the screen freezes at times and when i ran a diagnostics by holding down 2&4 it says ram no good.the service manual says replace the reader and if that does not work replace the main controller pcb 2 right now im lost can someone help me out and by the way i took all the cables off the reader controller pcb and disconnected the duplex adf and still the copier would come up with E732-001 someone help me this is driving me crazy
