ADF on IR Adv C5045
  • JVC
    • Jun 2011
    • 151
    ADF on IR Adv C5045
    I had a IR Adv C5045 that had a damaged adf. I replaced it with a feeder and the scanner from an IR Adv C5051. The new feeder copies both sides in one pass. The feeder will take the sheet past the pick up roller and stop just before the next set of rollers and give me a code of 010043. According to the information I can find this feeder should be compatible. Is there a setting that I need to change so the copier knows it has a different feeder or should it detect the change. I have tried initializing the sensors.
    Thank you in advance for the help.
  • northernlife
    • Sep 2011
    • 847
    Re: ADF on IR Adv C5045
    Copier > Option > IMG-RDR > Scantype
    0 is Reverse Duplex ADF and
    1 is for the single pass duplex df.
    under display > Acc-sts > Feeder is it 1 or 0?
    • JVC
      • Jun 2011
      • 151
      I do not see scantype under img-rdr it has dsdt and ds2dt
      It is set to 1
