Ir adv4235i
  • dickiebob
    • Sep 2011
    • 66
    [Error Code] Ir adv4235i
    Intermittent E315 -000D. It happens when printing from mailbox. Any idea?
  • northernlife
    • Sep 2011
    • 847
    Re: Ir adv4235i
    e315-000d jbig decode error,
    1. system software with an hdformat
    2. HDD
    3, SDRAM
    4. Main Controller replacement.
      • 16083
      Re: Ir adv4235i
      _____;-
      Performing HD-Clear for partition number 1 should resolve the error.
      The procedure is as follows: Level 1 Service Mode > Copier > Function > System > CHK-TYPE > set to 1. Level 1 Service Mode > Copier > Function > System > HD-CLEAR > Ok and turn the main power off.
      Could also be a memory dimm issue on main pcb 2
