IRC5185 questions
  • sql37
    • Jun 2014
    • 7
    IRC5185 questions
    Hi!
    I have just brought used Canon irc5185i with W2 finisher. I have folowing questions:
    -First question: When machine is printing, air is blowing from the paper output hole (picture). Is this normal? I'm little worried about this, because machine is old and has lot of impressions so i'm little affraid that toner particles from inside of the machine will blow in the enviroment (very small shop).
    -Second question: Is it possible to set the machine to print batch of 1000 sheets of paper with offseting every 50 sheets or set the machine to print to trays A and B each 50 sheets.
    -Third question: When printing pdf file or word file text is a little bit blurry and bold. I have tried PCL, PS, UFR2 drivers, without success. Photocopying is ok.
    Thank you for help.
  • teckat
    • 16083
    Re: IRC5185 questions
    Normal = OK on Fan ?
    14 Fans in this unit--------
    FM8=Delivery Vertical Path Cooling Fan /Cools the delivery vertical path.
    Symbol Name Function / Other
    FM1 Power Supply Exhaust Fan 1 = Exhaust heat in the power supply unit.
    FM2 Fixing Exhaust Fan = Exhaust heat in the fixing unit
    FM3 Main Body Exhaust Fan = Exhaust heat in the main body.
    FM4 Cleaner Fan = Ease heat in the main body.
    FM5 Delivery Cooling Fan = Cool the paper being delivered.
    FM6 Manual Feeder Cooling Fan = Cool the paper being fed manually.
    FM7 Controller Cooling Fan = Cool the controller.
    FM8 Delivery Vertical Path Cooling Fan = Cool the delivery vertical path.
    FM9 IH Power Supply Cooling Fan = Cool the IH power supply unit.
    FM10 Power Supply Exhaust Fan 2 = Exhaust heat in the power supply unit.
    FM11 ITB Power Supply Cooling Fan = Cool the intermediate transfer unit.
    FM12 Face-down Tray Cooling Fan (Front) = Cool the paper being delivered.
    FM13 Vertical Path Delivery Exhaust Fan = Exhaust heat in the main body.
    FM14 Face-down Tray Cooling Fan (Rear) = Cool the paper being delivered.
    • teckat
      • 16083
      Originally posted by sql37
      Hi!
      Thank you for help.
      2ND ? = Saddle Finisher-W2 is equipped with the following features: Collate, Group, Offset, and Staple (Corner, Double, and Saddle Stitch).
      Offset Mode
      The print output is shifted alternately to the front and back of the tray, in a vertical (portrait) orientation, or a horizontal (landscape) orientation depending on the orientation of your originals.
      NOTE;
      If you press [Offset] when either the Collate or Group mode is set, each set of prints is shifted before it is delivered to the output tray.
      Modes
      Non sorts: Escape tray, Trays 1 and 2
      Sort: Trays 1 and 2
      Staple: Trays 1 and 2
      *2 Equivalent of 81.4g/m2 paper.
      *3 Alignment accuracy and stacking capacity for stacks of 1700 or more sheets are not specified.
      *4 This applies when sheets (A4, B5, or LTR) of the same size are stacked in the non-sort mode
      Stacking capacity *2, *3 ,
      Escape tray: Non sort
      Large size: 43 mm high (125 sheets)
      Small size: 43 mm high (250 sheets)
      Tray 1
      : Non sort
      Large size : 96 mm high (650 sheets)
      Small size: 188 mm high (1300 sheets)
      Tray 2: Non sort
      Small size: 243 mm high (1700 sheets)
      Small size: 347 mm high (2450 sheets) *4
      Tray 1
      : Staple sort
      Large size : 96 mm high/50 sets
      Small size: 188 mm high/100 sets
      Tray 2: Staple sort
      Stapling By rotating cam
      Stapling capacity
      *2
      Small size: 50 sheets
      Large size : 30 sheets
      Alternating the Print Output (Offset Jobs)
      The Offset Jobs mode automatically sorts the print output by job when multiple print jobs are specified. It also ensures that output pages are always sorted even if you forget to specify a finishing mode.
      1. Press (Additional Functions) * [Common Settings] ->
      [Offset Jobs].
      2. Select [On] or [Off] -> press [OK].
      • teckat
        • 16083
        Hi!
        Thank you for help.
        3 ?--PDF's -----------do u have an external imagePass H1 Fiery Box CONNECTED
        u have an "i" model
        'Trace & Smooth' PDF mode enables users to convert the text of a scanned image to scalable outline data (vector graphics). The outline data is less jagged at the edge and the extracted outline data can be used in Adobe Illustrator (note that actual results may vary).
        * This mode is available only if the optional Universal Send PDF Advanced Feature Set (standard-equipped for the supported Color imageRUNNER 'i' models) is activated.
        - If users select [Trace & Smooth] as the PDF file format, [Compact] is automatically set to 'On'.
        - If users select [Trace & Smooth], [PDF (Trace)] is displayed as the file format on the Send Basic Features screen.
        - Users can also set [OCR (Text Searchable)] along with [Trace & Smooth].
        - Users can also combine [Encrypt] mode and [Add Digital Signatures] mode ultimately creating a document that is secure, signed, searchable and compressed.
        Users cannot send a Trace & Smooth PDF in any of the following cases:
        - If the document is scanned in the Black-and-White mode.
        - If the document is scanned in the Full Color/Grayscale (Automatic Color Selection) mode, and the resolution is set to other than 300 dpi.
        - If the document is scanned in the Long Strip Original (17" (432 mm) or more).
        Notes:
        - Trace & Smooth PDF is a functionality of PDF High Compression.
        - Users can combine Trace & Smooth PDF functionality along with Searchable PDF, Encrypted PDF, and Digital Signature Mode.
        - Users cannot Send a Trace & Smooth PDF under the following circumstances: If the file is scanned in B/W mode or if the document is scanned in the long strip original (17" or more).
        - Trace & Smooth mode may change look of font when enlarged or zoomed.
        The way a PDF will print is often determined when the PDF is created. For example, a PDF file can be created by printing using the Adobe PDF Writer driver. Before creating a PDF in this manner, be sure to enter the Adobe PDF Writer driver's properties to check its settings.
        When creating a PDF, there are many options to choose from for the Adobe PDF Conversion Settings.
        Please make sure to choose the option that best suits your needs. Standard is the default setting, which may not provide the best colors for printing. Standard, as explained below, is for viewing and printing business documents and not for higher end graphics files.
        Standard - Use these settings to create PDF documents suitable for reliable viewing and printing of business documents. The PDF documents can be opened with Acrobat and Reader 5.0 and later.
        High Quality - Use these settings to create PDF documents with higher image resolution for improved printing quality. The PDF documents can be opened with Acrobat and Reader 5.0 and later.
        Press Quality - Use these settings to create PDF documents with higher image resolution for high quality pre-press printing. The PDF documents can be opened with Acrobat and Reader 5.0 and later. These settings require font embedding.
        FieryOptimized - Acrobat 3.0 (PDF 1.2)
        FieryOptimized2 - Acrobat 4.0 (PDF 1.3)
        For best results on Fiery products, choose Fiery Optimized or FieryOptimized2 as shown below.
        NOTE: Some fonts cannot be downloaded to a printer, either because the font is a bitmap or because embedding of the font is restricted in that document. In these cases, a substitute font is used for printing, and the printed output may not match the screen display exactly. Ask the creator of the PDF document to send you a version of the PDF document with appropriately embedded fonts.
        • sql37
          • Jun 2014
          • 7
          Thank you very much for those answers.
