IRADV C5045 Will not boot up
  • RHodg57
    • Dec 2013
    • 191
    Got an IRADV C5045 that will not boot up. All I get is a screen with the so called sperm line that is only about a quarter to a third of the way
    along. I can't get it into diagnostics or download mode. I saw something close to this on another thread with slightly different symptoms.
    Someone said it sounded like a main controller 1 problem which makes sense. I reseated the dimms and the main controller one with no change.
    I tried a different HDD out of a good working machine and that didn't work. I will order a main controller. Just wanted to know if anyone has
    ran into this. I can't swap main controllers because the machines use different boards.
  • teckat
    • 16083
    Re: IRADV C5045 Will not boot up
    try re-seating connections on Main 1 & Main 2
    try and get in service mode on initial boot (can be done) check for error codes
    u probably tried this ?
    Controller System Error Diagnosis (Turn ON the Main Power Supply Switch while pressing the numeric keys '2' and '4' simultaneously)
    imageRUNNER ADVANCE C5051 / C5045 / C5035 / C5030
    part number for the Flash PCB (Boot Program) located on Main Controller PCB 1
    Flash PCB is FM4-0792-000
    stuck at boot up and will not come to ready.
    One solution to this problem was found to be the cable from the reader controller was not connected correctly. The tech reseated the connector at the copier and this resolved the problem. In the image below the edge of the connector is parallel with the surface of the metal.
    • RHodg57
      • Dec 2013
      • 191
      Main Controller 1 was the problem. Thanks Teckat!
      • teckat
        • 16083
        • tewamz
          Re: IRADV C5030 Will not boot up
          Am having a similar problem, My IRADV C5030 that will not boot up. All I get is a screen with line that is only about a quarter to a third of the way
          along. I have removed the memories and fixed them back, But still it can't boot. I have fixed the Main controller 1 cable properly but still it can't boot.
          Please how did you solve your problem.
          • teckat
            • 16083
            Part Number for the Flash PCB is FM4-0792-000
            The tech re-seated the connector at the copier and this resolved the problem.
            • RHodg57
              • Dec 2013
              • 191
              I replaced the Main Controller with an exchange from Nationwide. After trying
              everything else.
