using the USB printing of iR1600
  • iF2
    the online manual of my copier (Canon iR1600) say i can print directly using USB support. I opened a cover behind my iR1600 and saw a USB Plug and connected it to my computer, downloaded the pcl5e drivers but when iam installing and am asked to connect the device to usb and power on, it doesn't identify the copier (when i connect the usb cable to my computer, it identifies a new hardware "CanonCFYSA")but the driver setup doesn't see the copier keeps telling me "cannot recognize the USB connection". even when i continue with the windows new hardware "Canon CFYSA" installation, it doesn't find the drivers in the pcl5e driver folder.
    Dont know what to do, PLEASE HELP
    NB. the Copier automaticaly reset every time i connect the USB cable to my computer.
  • xcopytech
    • Aug 2006
    • 1794
    This USB port is for firmware upgrade ONLY.
    Can not use it for printing.
    • iF2
      Thanks man "I Was Lost" ... THEN HOW CAN I print throw this copier
      • djbass
        • May 2008
        • 164
        It needs the optional Printer Board-N1 installed in order to utilise the USB/Parallel printing ability. They do not come with printing support as standard.
        No, I will not send you Manuals, Software or your own little repair Genie to fix all your problems for you.
        • iF2
          thanks man
          • screenshot
            Re: using the USB printing of iR1600
            can you also scan into the computer via the usb port?
