I am trying to get around a e020-0186 error. Is there a way to disable ATR? I am thinking disabling pascal would do it, but not sure. Print quality is perfect just need to get machine running, can remedy problem later.
imagepress C6000 e020-0186
Tags: None
Re: imagepress C6000 e020-0186
If u disable ATR u can have alignment issues
try this instead---
in Service Mode Level 2 > COPIER > ADJUST> DENS > P-TG-Y = Adjust to "0"
The position of patch images is different between Y/M color and C/Bk color, the position of the Drum Patch Sensors is different.
In addition, patch images of Y/C color and M/Bk color are formed alternately between sheets.
Since the position and timing to form patch images of 4 colors are different, the patch images of 4 colors are not overlapped on the ITB.
Image density is too low
As possible causes of low image density, soiled primary charging assembly, faulty laser, soiled dust-proof glass, faulty drum, faulty developing, and etc. are conceivable. However, faulty developing is the most likely. For this reason, check the area around the developing assembly first.
1) Check the area around the developing assembly.
- Are there occurrences of Tiger stripe?
- Are there occurrences of developer overflow?
If these symptoms have occurred, replace the developer after taking actions actions such as cleaning.
2) If there is no abnormality found at the step 1, output PG5 of the corresponding color with density settings '80' and '255. Check the density and unevenness.
U have a YELLOW ISSUE---Guess u know that already
Possible Soil on the ATR sensor
did u clean it ???
-Faulty pressure for Y developing assembly
-Broken wire of ATR sensor
-Damaged ATR sensor
-Malfunction of ATR patch detection shutter
e020-0186
x= 1:Y 2:M 3:C 4:Bk
0x86 = Fault at sampling 2 in patch image
DISPLAY>DENS>DENS-S-Y/M/C/K(Measured value of patch image) -
DISPLAY>DENS>P-B-PY/ M/C/K(measured value of drum base) </= 30
1. PG05-96 (D)
Single color/4C
Check uniformity of the image
-> Check the developing motor
2. Check the DISPLAY>DPOT>P-LPW-Y/M/C/K (patch laser power value)**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
P-LPW-Y
Y-color laser power of patch contrast target potential
Lev.2
Details To display the Y color laser power required for patch contrast target potential in the potential control.
If the value is out of the appropriate range at the density failure, the toner supply control may be a factor.
If it is within the range, investigate the other factors.
Use case - At the occurrence of an image density failure
- When analyzing the cause of a problem
Display/adj/set range 00 to FF (hexadecimal)
Appropriate target value 60 to FF**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
After getting the e020-0186 error I noticed these values.
COPIER>DISPLAY>DENS>P-B-P-Y = -56
COPIER>DISPLAY>DENS>P-B-P-M = -56
COPIER>DISPLAY>DENS>P-B-P-C = -56
COPIER>DISPLAY>DENS>P-B-P-K = -56
Seems strange that all colors would be -56. Any ideas?Comment
All values are equal and way too low...maybe the mashine codes out on yellow, because yellow is the first color measured and there is now time to throw other errors. So it leads you to a false direction.If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!Comment
I have switch sensors, drums, coruna, grid, same error no matter what.Comment
