First time we have come across this code, did the basics cked fuser connectors and even tried another fuser assembly, pops code after service reset. before getting to board replacement i was wondering if there is something else to check. Thanks
irc 5185 e731-001
Re: irc 5185 e731-001
Not a Fuser Code issue-
E731=UFR PCB error
E731 is a UFR board ( Open Interface pcb) issue.
(in parts manual called RB-A PCB)/
Slot Location in lower left of Main Controller
Check the UFR PCB connections
Remove> clean ends > Re-seat
The sub controller RB-A PCB may not be installed or seated correctly.
The PCB is held to the main controller by clip locks on the main board and a tension bracket that holds the board to the controller box assembly. Remove the bracket (with tension mount) and re-seat the Sub controller RB-A PCB to the main controller. Then re-install the tension bracket.
UFR-.JPGLast edited by teckat; 06-30-2014, 05:03 AM.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
