IR5075 E000005-001
  • DTarry
    • Jun 2025
    [Error Code] IR5075 E000005-001
    Replaced web as Error would imply, reset count (copier>counter>misc>fix web) and durable1 count, replaced WG8-5708-00 web sensor, Checked P-CON I/O P005 and bit 15 is a 1 went to DC controller checked J101 pin 1 and 2 no 24 volts (all other voltages are present on J101) Replaced Main Power Supply FK2-3472-000 and still getting E000005-001. I think there is a PURS signal that comes from the DC controller to turn on the 24v on the power supply, is this a possibility as I am running out of options. This has been a nightmare of a repair so far. What's next?
  • teckat
    • 16083
    Re: IR5075 E000005-001
    ACC power supply PCB -generates DC power from AC power -protects against over-current
    -power supply to reader and charger unit/
    DC power supply PCB -generates DC power from AC power -protects against over-current/
    did u check your Main Switch /
    if faulty > will not supply the 24VU2/3/4 supply needed
    • spectraindo
      • May 2008
      • 313
      E0005-001 means there is no current detected through the web solenoid, I have a similar case when the 24 Volts from the DC Power Supply is missing.
      Replacing the DC Power Supply fixed the problem.
      Check the 24 Volts wiring for shorts.
      • Canuck
        Tech Specialist
        • 1713
        Make sure there is no paper smushed(?) into connector at rear of fixing drawer or inside connector on machine. Look very closely inside the connectors
