Hello everyone, my CANON IRC 5185i does not print, but copies correctly,, when I start printing from the computer, or test page local printing machine, the printer stops and then restarts, j cleaned all the components electronics parts ;;; changed a ;memory card RAM, but the problem remains, I think a reinstall the firmware,, please if someone can direct me to find the firmware it'll be very nice thank you
firmware for irc 5185i
Re: firmware for irc 5185i
Your reboot only occurs when printing from the network
the sub R-A PCB could be faulty.
i would also check that sub RB-A pcb/ remove and re-seat
known as the UFRII pcb.(standard print kit in "i" series/ unless u disabled it to install a imagePass Fiery H1
if u installed a H1 Fiery> slot #1 will have a sub RA-O (Open IF PCB) for Fiery
remove & re-seat it >also check ot's I/F Cable if this applies to you
also check the FIX UNIT temp readings/ have seen this on a few of these models/ when sending Prints .
have u tried using a Laptop to Print ?Last edited by teckat; 07-07-2014, 06:54 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.** -
Try this Clear here
COPIER>FUNCTION>CLEAR
ERDS-DAT = Embedded-RDS SRAM data clear
SCM data in the embedded-RDS SRAM are restored to the factory settings.
before u clear anything> u need to print out P PRINTS >that have settings needed to re-input
RCON or DCON clear is a waste of time for your issue-------
Also this MMI & MN-CON is a waste also> don't do it
MMI = Clears following user mode setting values:
- Backup data for copy operation panel (user-set values)
- Common settings backup data (user-set values)
- Backup data (except fax data) (user-set values)
The setting values are cleared after the main power switch is turned OFF/ON.
Operation method
1) Select this item, then press the OK key.
2) Turn the main power OFF/ON.
MN-CON = Clears RAM on main controller PCB's SRAM board.
- The RAM is cleared after the OK key is pressed.
- Performing this item initializes all the data on the SRAM board. In other words, file management information for the hard disk is initialized, and image data on the hard disk can no longer be read.
Before performing this item, explain to the user that all images in the BOX will be lost, and receive permission to perform.
Operation method
1) Select COPIER > FUNCTION > MISC-P > P-PRINT to print out the service mode setting values.
2) Select this item, then press the OK key.
================================================== ============================================**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
hello teckat the problem steel the same , but i missed to talk about something "" when i run the print job "" i have some works with NG ( #852 ) i think it's an memory truble bcause is there more than 5000 works ,,,, now i need to know how i can erase all of theese works , in sav i tried with many cleaning but i didn't found the good clean to erase it thank youComment
Try clearing in RUI, open browser, type in Printer IP address to open, see if u can clear jobs
Make sure u don't have lower issues interupting jobs.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
no i never print with network , i use only usb ,,,,,, but recently an technical's comming may be he tried to insert an ip adress ,, please tell me what i have to do in both cases , and how can i be sure that the machine are networked or no ,, thank youComment
Print jobs are not held in HDD.
Where do u see these jobs ?
On PC\ LAPTOP ?
What are u talking about initilalized ?
U mean MN CON CLEAR ?**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
i printed many of them by pc
others : in local printing of the machine "without a PC or laptop", cmyk print test, rgb, and the configuration page ,,, before when I print local test machine, it was ok, but now the printed
pages are encrypted and unreadable , and when i print from the pc ,, the machine's stop and restartLast edited by win32; 07-25-2014, 07:52 AM.Comment
Additional Functions>System Settings>Restrict Printer Jobs.
Check This setting ?
Make sure it is set to OFF.
After setting it to off, print jobs should again printing
Did u ry a MN-CON CLEAR in service mode ?
Or------>
Perform an MMI Clear ----To clear MMI, perform the following steps. Service Mode > Function > Clear >MMI
*Note Be sure to run a User Data Report before performing a MMI clear, because the IP address will be cleared out during this operation.
Additional Functions > Common Settings > Standard Local Print Settings > Erase Document After Printing > set to "ON"Last edited by teckat; 07-27-2014, 09:56 PM.**Knowledge is time consuming, exhausting and costly for a trained Tech.**Comment
Or------>
Additional Functions > Common Settings > Standard Local Print Settings > Erase Document After Printing > set to "ON"Comment
i tryed to follow this steps , but there is no way in the brwoser to delete a print job ,,,,Comment
