i have a c5035 setup for the CPI credit card system to track prints. everything works perfect except that i cant figure out hot to get the machine to charge for prints from the computers setup on the c5035. when you need to make copies you swipe your credit card and your done after the job is finished you get your resiet and the process is finished. but if you want to print something to the machine from the workstation it will let you do it for free. i dont know where in the setup menu in the copier too set so that it charges all types of printing. hope that makes sense and that i can get some help. thanks
Re: CPI credit card system
for charges on PDL PRINTS
To set charge count transmission of PDL job to the connecting charging management device (coin manager or non-Canon-made control card).
COPIER>OPTION>USER>CONTROL set to "1"
It then waits for either the access code to be entered or the access card to be inserted.
Set to 0=NO CHARGE if you DO NOT want to charge for PDL print jobs (the print jobs will print and will not pause)
Set to "1"= CHARGE if you want to charge for PDL print jobs (the print job will pause until you satisfy the third party unit)**Knowledge is time consuming, exhausting and costly for a trained Tech.**
