screen showing this [root@(none) SysMaintecA /]#
  • yazj
    • Aug 2011
    • 29
    Hi all,
    any body encounter this problem in iRADV C2020L before?
    thanks & regards
    Yazj
  • Kalamar
    • May 2014
    • 23
    Re: screen showing this [root@(none) SysMaintecA /]#
    Looks like a software problem! Root@ and such is shown on a linux shell normally, so maybe somethin is wrong with the installed firmware!?
    does it appear directly after you switch on, or is the machine booting "normally" and then, when you should see the user interface this appears?
    • northernlife
      • Sep 2011
      • 847
      I want to know how to get to that shell to be honest with you :-)
      I'd reload software. I've also never run into this whatsoever nor have I heard about being able to drop into a shell.
        • 16083
        Originally posted by yazj
        Hi all,
        thanks & regards
        Yazj
        Memory Dimms on Main Controller 1>
        remove>clean ends>re seat
        or replace
        or as stated Format the hard drive and reload system software
