Internal Finishing Unit Stacking Problem C2550
  • Rayelias
    • Jul 2014
    • 8
    [Misc] Internal Finishing Unit Stacking Problem C2550
    Hi,
    One of my clients has a Canon IR C2550 with an internal finisher. Now the problem is:
    1. The finisher outputs just 10-15 pages and stops.
    2. Then it prompts for these pages to be removed and works fine till the next 10-15 pages are printed.
    3. Rinse repeat.
    This problem has really flummoxed us all and I've never seen anything like this ever happen before. Basically my client can't print any large document.
    One thing that I did notice was that the finisher "base" keeps adjusting [up and down].
    Maybe we can stop these adjustments to get a solution?
    Thanks again. Please do let me know what more info I need to post.
  • northernlife
    • Sep 2011
    • 847
    Re: Internal Finishing Unit Stacking Problem C2550
    Service mode level 2 > Copier > Option > User
    TRY-STP Used to set mode in which output stops when tray is full.
    0: Normal mode (Interrupted when finisher tray is full.)
    1: Interrupted only by height detection
    basically change it to whatever it isn't atm.
    • Rayelias
      • Jul 2014
      • 8
      Thank you so much ! I will try tomorrow and let you know how it turned out.
      • teckat
        • 16083
        too add on--for Z1 Finisher if applies to your printer
        Check the paper surface sensor SR11's Actuator and the Actuator's Spring.
        Inspect the Actuator and see if too loose, that would cause it not function/return properly.
        if this is the case>add an extra wrap to the actuator's spring
        Z1
        Stack (number of sheets/stacks)
        Non-bound small-size
        *1/ 71 mm or less in height or more than 500 sheets (81.4 g/m2 paper)
        large-size
        *2/ 35.5 mm or less in height or more than 250 sheets (81.4 g/m2 paper)
        staple sort
        30 sets; or, height indicated above; of 81.4 g/m2
        Size mix
        500 sheets or 71 mm or less in height (81.4 g/m2 paper, proper stacking not guaranteed)
        staple mix/
        mode mix
        30 stacks or 71 mm or less in height (81.4 g/m2 paper, proper stacking not guaranteed)
        Stack Tray Operation
        The stack tray paper sensor (SR11) goes on when a stack of sheets is newly deposited on the tray. The stack tray is moved up and down by the stack tray shift motor (M7). The stack tray home position is where the stack tray upper paper surface sensor (SR9) is off and the stack tray lower paper surface sensor (SR10) is on.
        If the stack tray is not in home position at the start of a coy/print job, the stack tray ascent/descent motor is driven to move the tray to home position.
        The upper limit of the stack tray is monitored by the stack tray upper limit sensor (SR13), while its lower limit is monitored by the stack tray lower limit sensor (SR14). If any of these sensors is on, the stack tray shift motor may be driven in such a way so that the stack tray will move in the direction opposite the sensor that is on.
        • Rayelias
          • Jul 2014
          • 8
          Thanks to all of you! The Actuator's Spring was malfunctioning and causing the problem. They tried all the other methods first and then the Actuator Spring was taken care of.
          • teckat
            • 16083
            Sometimes it right in front of the nose.
