IR3235 LSU
  • Jeff M.
    • Dec 2010
    • 127
    IR3235 LSU
    Looking for a used laser scanner for an IR3235, #FM3-5041. Getting a E110-0002 error.
    Cable is OK, shutter is opening when you close the door. Tried cleaning the ground strap on the chrome roller. Nothing. Paper stops at the fuser and is blank, gives the code then.
    Thanks, Jeff M
    • 16083
    Re: IR3235 LSU
    Thanks, Jeff M
    System Software v42.01.04 for the imageRUNNER 3225/ 3230/ 3235/ 3245 copiers to address a wireless LAN and E110-0002 issue.
    this was for an issue while printing from stack bypass & paper runs out/
    not your case/ Just for information
    check DC CONTROLLER>J304>pin 4_24V to pin7_GD = for 24v
    did u check routing of the shutter cable / IMPORTANT
    u need to remove Fax board to provide viewing clarity.
    http://www.iteminconline.com/fm3-5041-000_fm3-5041-000-canon-
    ir3230-laser-scanner-assy.htm
    300.00
