You get them on a cd when you buy the printheads. Other than that you need extranet access with canon themselve in order to download the firmware. However there's always a nice laddy somewhere on here that'll toss you a copy.
Edit: Just checked and I don't have access to the ipf firmware, just service info :-(
================================================== ================== Change History
Main Changes in Ver.1.38 from Ver.1.36]
To optimize the method of counting the internal counter, in an effort to improve reliability.
Main Changes in Ver.1.36 from Ver.1.34]
If clogging occurs in the nozzle, and was continued printing by pressing a "line key" After confirming a print image to stop the printing conventionally, by automatically determining the level of clogging, printing is possible Continue to print, we have improved to display the head exchange messages in a state that requires head exchange in the state. Workability will be greatly improved by changing the above.
For paper that has been added in the media configuration tool, we fix a bug that there is a case to the failed automatic band adjustment.
"Paper Advanced" / was revised "to return to the initial value" function.
Main Changes in Ver.1.34 from Ver.1.32]
It added a paper jam detection function using the cutting operation.
There was that the ink filling is not completed successfully in the initial installation. I have fixed this bug.
It has improved the message of ink remaining amount detection Disabled in Japanese other than display.
Main Changes in Ver.1.32 from Ver.1.31]
It now supports "premium glossy paper", "Premium Semi-Gloss paper", "premium glossy paper (Thick)", "premium semi-glossy paper (Thick)" to.
When the load of the carriage movement is heavy, This has been fixed in which the carriage may stop to display the "2F26" error even in the level that can be normal behavior in nature.
Use the 44inc roll, printing custom size of 60m or more or banner, This has been fixed to stop in about 10cm print start at 2400dpi.
Main Changes in Ver.1.31 from Ver.1.20]
It changed to lowercase letters of the alphabet HEAD LOT NUMBER status of print.
Main Changes in Ver.1.20]
It is now able to print if the number is small, to reduce the amount of ink to be used in cleaning.
It added a setting to hide the paper mismatch error.
It has conformed to the standard of the 2007 Energy Star.
Download file from internet then updated the printer and still shows 1.38 any ideas
[ATTACH=CONFIG]25685[/ATTACH]
--------------------------------------------- what ver of Windows is your OP System ???
believe u need LPTool v1.80 for Win8 support
Believe u can downgrade using the L Printer Service Tool
1) Install L Printer Service Tool on the PC.
2) Identify the firmware version and copy the firmware to a specified folder on the tooling PC.
(Default destination directory: C: \Program Files\L Printer Service Tool\Data
3) Start the printer in Download Mode.
4) Launch L Printer Service Tool.
5) Connect to the printer, choose the firmware you want to downgrade from L Printer Service Tool and click Transfer Firmware to start a transfer.
6) When the transfer completes, switch off the printer to restart it.
Upgrading (downgrading) firmware
■Download firmware
Starts a firmware download.
■Firmware specifications
-Optional directory specification (default)
Firmware that can be updated is selected automatically. (The firmware can only be updated.)
-Optional file specification The optional file (firmware) specification allows the firmware to be upgraded and downgraded.
■Forced download mode Do not use Forced Download Mode in usual operations. If Forced Download Mode is run by mistake, the main unit may become unable to start because the firmware file check, model check, and printer status check are disabled. In this case, the main controller would need a replacement.
or >>>>>>
u may need to try this downgrade method first>>>>>>>>>>>>>>
Link was Sent to me by my tech friend
How to Downgrade IPF Firmware----
Get the Canon firmware JDL file from within the data folder of the firmware update tool, you can do the back date. I prefer to use a 3rd party tool, the standard Canon tool will not allow a back date.The Kodak File Print Utility (EFPU) is perfect for it. EFPU310.EXE (LINK BELOW) http://www.wideformat.kodak.com/support/Tech-Support-Resources/ENCAD-Tech-Support-Utilities/index.asp
Install the tool, make a new master folder and call it firmware, then add the firmware file to the new folder.
Change the option for 'files of type' from 'RTL' files over to 'all' files when browsing for your firmware jdl, otherwise the program will not see them.The software allows you to send the data via a print button, it sends to all ports that are available in windows print manager.Make sure you have a printer driver for the Canon installed to the correct port.
