Iradvc2020 blur print and e020-0360
  • gohkahwai
    • Jun 2014
    • 4
    This machine change new black drum,toner feed unit,new toner and
    laser unit take out to clean.
    after tested print around 2k page problem come out again.
    any solution to solve this issue.
  • Nutstar
    • Mar 2011
    • 110
    Re: Iradvc2020 blur print and e020-0360
    I've got a machine with a similar issue that we are now at the point of getting canon to come have a look.
    have you changed the patch sensor?
    have you checked to make sure the patch is appearing correctly on the ITB during warmup? (remove the delivery tray cover and power up the machine, view the patches on the front side of the machine where the K patch is generated).
    if the patch is fine but it errors replaced the patch sensor.
    • teckat
      • 16083
      Blur ?
      that mean a lot on a COLOR PRINTER
      Did u Perform a REG-CLR in Service Mode, and then running a Auto Correct Color Mismatch & Full Auto gradation to try and correct the Color Registration issue.
      COPIER > FUNCTION > CLEAR > Lv.2
      Using OEM BLACK DRUM
      The new style hopper is installed.
      Registration Patch Sensor checked or replaced
      Cleaned the laser glass with the glass cleaning tool located inside the front cover,
      E020
      -0360 refers to the ATR patch failing to be created correctly or a patch sensor error.
      Try replacing the black toner bottle OEM
      Make sure the contact for the black developer is NOT bent, this causes a poor connection between the black developer and the DC controller. The part number for the contact is FM3-8111-000. See the following photo of the damaged developer contact.
      • gohkahwai
        • Jun 2014
        • 4
        morning all,
        Toner in original and hopper in new one,Path sensor not yet replace.
        may i know how to the calculation the toner value in this machine.
        my machine the DENS>REF> value now is below 55 value in not normal.
        • teckat
          • 16083
          morning all,
          that reading has nothing to do with a BLUR issue>>
          time to troubleshoot issue> develop a check list plan
          • aco.bk
            • Sep 2012
            • 130
            read this.
            • teckat
              • 16083
              Originally posted by aco.bk
              read this.
              good information
              wish posters would list exact models & serial numbers > helps with pubs that list affected boxes
              just found this pub from y2013
              C2020/C2030/C2225/C2230
              x= 0: Y, 1: M, 2: C, 3: Bk)
              E020-0
              x60/ E020-1x60 Error Code or a 340001/340002/ 340006 Alarm Code may occur due to the tension spring in the Secondary Transfer Roller
              Assembly Unit coming off.
              E020-0x60_E020-1x60_IRAC2020.pdf
              • AhLeong77
                • Jul 2014
                • 8
                As GohKahWai had mentioned earlier, we had replace the new NPG-52 BK Drum, the new Toner Feed & cleaning & servicing everything. But the best result is only last a few thousand copies. The affected machine serial is FAN13099. Here I also attach a sample of the PG10.
                • teckat
                  • 16083
                  --_---_--
                  Need to look at both tech pubs,
                  Black is being starved
                  • AhLeong77
                    • Jul 2014
                    • 8
                    Originally posted by teckat
                    --_---_--
                    Yes, it's look like the Black is starved. As we double check the Toner Feed, there are toner inside. So today, GohKahWai also replace the Patch Registration Sensor together with the BK Drum. The sad parts is the same problem again. The black began to turn out blur. As the reading is Display>Dens>Dens-K> -0.20%. This is the 3rd unit, we facing the same fault.
                    The first unit we had replace everything as following from the service manual & additional with the Main Controller PCB but still cannot solve the failure. The second unit is just parked in our workshop.
                    • Canuck
                      Tech Specialist
                      • 1713
                      Try swapping laser assembly. Have seen issues caused by bad lasers on these units
                      • AhLeong77
                        • Jul 2014
                        • 8
                        Yes, sir!! The Laser Unit also new!! But fault still persist
                        • Canuck
                          Tech Specialist
                          • 1713
                          Ram clears and install newest firmware?
                          • AhLeong77
                            • Jul 2014
                            • 8
                            Ram already been clear & the newest firmware apply also. Waiting for Canon to issue a new firmware for this issue!!
                            • teckat
                              • 16083
                              That White Gap in PG10 is a Laser Issue
