E121-001 (IR6570)
  • megacopiadoras
    • Nov 2011
    • 17
    [Error Code] E121-001 (IR6570)
    I have a IR6570 and when I turn on the machine it shows the code E000121-001, have changed the FM4 fan controller and still the same problem. When I check the voltage on the cable 10V FM4 time comes and she calls and suddenly she gets 0V and display code. Have disconnected J108 and nothing help me.
  • teckat
    • 16083
    Re: E121-001 (IR6570)
    Fan has 2-speed control (voltage) (24/12 V)
    controller cooling fan
    cools the laser unit,developing block drive block, and controller
    u can't disconnect J108=ERROR CODE will pop
    trace V back to supply source/DC power supply
    also> make sure your front door switch is working
    click on pic
    • megacopiadoras
      • Nov 2011
      • 17
      I put the DC Controller this machine that has the code on another machine, and the code presented in another machine also.
      Will DC CONTROLLER.
      • teckat
        • 16083
        Will DC CONTROLLER.
        If dc pcb shows issue in another same model,
        means / the signal for fan on is poor.
        Did u swap the working dcpcb to problem printer ?
        • megacopiadoras
          • Nov 2011
          • 17
          I never do that, would be more appropriate, since it already testing the fan and even this ok?
          • canonservis
            • Jul 2014
            • 3
            i haw same problem on IR5570 when I turn on the machine after 5/6 sec it shows the code E000121-001, changed the fan controller and still the same error .front door switch is working ok
            what to do ?
            • teckat
              • 16083
              what to do ?
              what about the FM4 fan ?
              Did u Check the connector for any fault in connection.?
              Did u check voltage supply ?
              as noted above that Fan is a two stage voltage (24/12 V) unit
              • megacopiadoras
                • Nov 2011
                • 17
                already solved the problem really was the dc plate dcontroller, thanks to everyone who lost a little time.
                • lilleputte
                  • Jan 2013
                  • 153
                  Hi , Old post but replacing the dc-controller was the solution for me
                  • copyhere
                    • May 2009
                    • 112
                    I have the same problem and was wondering if one of the resistor fuses on the dc controller could be bad? I cant find a dc controller circuit diagram in the service manual. Does anyone know what the fuses FU1 to FU20 on the dc controller are for I know one of them is for the hopper motor i had changed before. Im looking if one might be for the fan #4.
                    • mehta
                      • Oct 2010
                      • 11
                      Fix with modification in DC controller one rectifier added in fan controller circuit. Problem shortcut successfuly.
                      • mugensosa
                        hey bro, can u explain me where u fix the problem? i cannot find anywhere :S
                        thx
                          thx
                          please review the WHOLE thread... fix was given there
                          megacopiadoras
                          Rep Power18
