iRC4080 Black Laser to home Position
  • Smartmind
    • Aug 2011
    • 61
    Hello All! I need to know how to set the iRC4080 black Laser to home position Manually?
    I know how to set color's laser to home position, But I'm not sure about Black Laser home position.
    Any help would be appreciate, Thanks in advance!
  • Smartmind
    • Aug 2011
    • 61
    Re: iRC4080 Black Laser to home Position
    I mean, Is there any difference between black and color laser home position? sorry I wasn't clear enough in the above question.
    • teckat
      • 16083
      NO ALL THE SAME <> see PDF Color Shift Prevention / Correction
      -----What is your issue
      • canonbundy
        • Jun 2012
        • 607
        SRV Mode 2 > FUNC > CLEAR > REG > FUNC > LASER LD Y-M-C.
        ADD FUNC > Perform Quick Adjust > AUTO COLOUR CORRECTION.
        • Smartmind
          • Aug 2011
          • 61
          Thanks both of you boys by replying, I already fix this issue, (vertical lines color displacement) I set the black laser to Home position and entered the original p-print original values, now machine is working, but this afternoon someone in the office was making some black prints and got this error code E000747-051C, any suggestion is appreciate.
          • teckat
            • 16083
            Remove & clean board ends ,then reseat all boards on the main controller.
            • Smartmind
              • Aug 2011
              • 61
              Thanks! I was thinking the same, I will do that tomorrow.
              • teckat
                • 16083
                Don't forget memory ends,
                • Smartmind
                  • Aug 2011
                  • 61
                  Thanks buddies! Boards cleaned and reseated this morning, everything worked fine, but this afternoon somebody told me that machine shows a new massage (Finisher can not be used), they say that the machine can do prints and copies, but finisher x1 is not working properly.
                  • Smartmind
                    • Aug 2011
                    • 61
                    I just went to turn off Limited functions, Easy Money!
                    • teckat
                      • 16083
                      ---_---
                      Ain't this field Easy ;-?
