canon ir 5570
  • Saji
    • May 2010
    • 97
    canon ir 5570
    Canon ir 5570, feeder not sensing B4 size paper,i replaced the VR from the feeder tray,tried service level 2, option-body-sens-cnf set to 1.but still the problem persists, pls help, thanks in advance.
  • Brian8506
    • 1664
    Re: canon ir 5570
    Did you do the adjustments under feeder/function
    • Saji
      • May 2010
      • 97
      Re: canon ir 5570
      thanks for your reply, will you pleases guide me what adjustments are to be made to solve this problem, thanks.
      • Brian8506
        • 1664
        Re: canon ir 5570
        If I have the right screen there should be
        If I have the right screen there shoud be 4 paper size setting. I believe A5' A4R' ltr and lgi. Set the guides to each size' highlight it on screen and press ok. No paper in df when adjusting.
