I am look at service mode.The machine can't detect LGL original size on DADF. Please advice.
iRADVANCE C5051 Can't detect LGL original size on DADF
Re: iRADVANCE C5051 Can't detect LGL original size on DADF
did you run the width adjustments on the df? Does it recognize fine on the glass? -
Do a width adjustment in service mode (all 4) and run a sens-init. I'd try doing a clear on the rcon just for shits and giggles.
IO mode rcon p003 bit 4-7 will show you if sr17-20 are functionining. when you press them down the bit should change between 0 and 1, if not you got a blown SRComment
then width adjustment and check if the machine sees the length sensors operating fine.Comment
