Canon ir 2380 drum replacement
  • dickierock
    • 252
    Hi,
    I am mainly kyo /konica tech so havn't worked on many canons but the k drum needs replacing and looks easy enough to do.
    Just wondering when the drum unit is replaced do I need to reset in the maintenance mode or is the drum chipped?
    Anything else like pm counters that I should reset?
    Thanks.
  • MFPTech
    • 486
    Re: Canon ir 2380 drum replacement
    Originally posted by dickierock
    Hi,
    Thanks.
    Canon machines do not display a warning for drums but you can check / reset the counters in Service mode under counters / durables 1.
    Hope this helps.
    • dickierock
      • 252
      Hi MFPTech,thanks.
      The drum needs replacing alright,so i need to know how to get into service mode and how to reset the drum unit counter and pm counter if available.
      Thanks.
      • ernesto
        • Oct 2011
        • 430
        Hi
        IRC 2380 does not need to reset drum, it is automatic.
        What do you have to do when you replace a drum in a taskalfa 250ci?
        All the best
        • dickierock
          • 252
          Hi ernesto,thanks,
          Is there a pm counter to reset? If so how do I get to maintenance mode?
          Re; 250CI
          After drum replacement,in maintenance mode
          perform U119,Drum set-up
          U930, Clear charge roller
          U464, Ac Calibration
          Colour Cal + Reg
          U412, Density
          U410, Halftones.
          All the best
          • Kalamar
            • May 2014
            • 23
            • Harry
              • 228
              ther is a chip on this drum
              good day
