IR5000 DF Multi feed
  • Brian8506
    • 1664
    According to this tb, they were supposed to update the pad. The ones I get don't have white dots and I have a couple high volume machines that have this symptom. Anybody ever hear of a new pad?
    MODELS AFFECTED / SERIAL NUMBERS AFFECTED:
    imageRUNNER 5000 Series, imageRUNNER 7200
    SUBJECT:
    DADF-D1 Multi-Feeds or Jam Code 0002
    Page 1 of 2
    TP04 188.pdf
    08-06-04
    e-Support Filename:
    Date
    GENERAL:
    Due to a malfunction in the manufacturing process, the step to add a tacky surface coating that creates the
    friction coefficient of the DADF-D1 Separation Pad was compromised and the pad did not meet the factory
    specifications.
    DETAILS:
    During a two-month period beginning in June and ending in July, Separation pads that were manufactured for
    the DADF-D1 on the imageRUNNER 5020/6020 failed to meet factory specifications for friction coefficient.
    This results in a symptom of Multi-feeds (Jam Code 0002) in the DADF-D1. During this time Canon USA
    service stock was also affected as well as some DADF-D1 80K Feed Handy QA kits sold by us.
    SOLUTION:
    Canon, Inc. has rectified the problem and is in the processes of sending verified Separation Pads marked with
    a white dot to our warehouse. These verified pads continue to use the original part number (FF3-3983-000).
    The white dot will be used for a limited time until the part number is changed (to be determined at a later
    date), and then eliminated. A Technical Publication will be published at a later time informing you of the part
    number change.
    White Dot to indication a verified Separation Pad
  • kiwitech
    • Oct 2012
    • 29
    Re: IR5000 DF Multi feed
    its been at least 5 years since i worked on one of these but i do remember a new pad with white dot. however i see in your attached info they will discontinue white dot and change the part number at some stage so i think its been such a long time that probably the new pads no longer have the dot but may have a similar part number with maybe the last 3 digits different. if you replace the pad with new stock it will solve the problem.
    • Brian8506
      • 1664
      To my knowledge, there is no new part #. I ordered one of the other part numbers assigned to the pad and get the same part. I recently ordered the coarse pad only from DADF n-1 for 3570 etc. I cut it to size and so far its working like a charm. If they did update the part, it's no better than the original. IR2200 series was the same way but the 3570 series pad fits in there as long as you add the white mount plate on the bottom.
      • kiwitech
        • Oct 2012
        • 29
        i'll make a note of those substitute parts you mention. sounds like you've solved the problem !
        • Brian8506
          • 1664
          That's the feed roller. I'm talking about the sep pad FF3-3983
