Canon IR5570
  • jtblank
    Canon IR5570
    Trying to replace the cracked LCD display touchscreen, any tips on getting the top panel off to get to it, looks like two screws holding it on, one on each side but hard to get to as the toner mechanism is in the way on right side. Once the two screws are out does it just lift out?
    Any suggestions are appreciated.
  • vigour
    • Aug 2010
    • 1038
    Re: Canon IR5570
    Remove finisher
    Remove upper panels on each side (fuser side and Manual feed side)
    Remove copyboard glass then remove front long panel between copyboard glass and control panel
    This will reveal about 3 screws between control panel and reader (Look DOWN )
    You will find 1 or 2 screws to the right and left of control panel
    Control panel should now lift off. Remove connector/s
    Turn upside down, remove grey panel
    Remove connectors, be careful and observe the ribbon cable connector.
    About 25 screws later you will be ready to remove the pcb unit with touch panel
