IR 3570
  • justo
    • May 2025
    [Jamming] IR 3570
    Dear all,
    I'm facing a jam when the paper rich the fuser unit.
    Any help please.
  • babai
    Re: IR 3570
    you should check the fusher film , i think it's not rotating perfectly . apply some
    silicone oil on it .
    • northernlife
      • Sep 2011
      • 847
      Re: IR 3570
      jam code? 70 series has a fixing film rotation detection sensor, if it was slow at all you'd be getting e007. So there's a flapper on the door that opens that has black foam pads that were malengineered and cause sticking. The paper will stick out about an inch and jam with sort of a wave in the page. Delivery flapper is what you're looking at. If that's not it the inner delivery drive gears may not be meshing properly with the drive from the fuser. Third is the lower right door mod. Other than that I personally love this units. very little service required.
      • justo
        Re: IR 3570
        Thanks,
        The problem was the bearings, film rotation detection sensor and thermistor, as soon as everything has changed everything is back in order.
        thank you very much
