Canon IR3300 no image, no error
  • greyrock
    • May 2025
    [Misc] Canon IR3300 no image, no error
    Hello group, my recently acquired (free) Canon IR3300 has no image on the paper. There are no error codes, and all functions work fine, scan, paper feed, display, etc. and the toner is full. The fax function works when sending a fax, so that indicates the scanner is fine but when printing, receiving a fax or making a copy, the paper has no image. Any thoughts on hopefully an easy fix? Thanks!
  • northernlife
    • Sep 2011
    • 847
    Re: Canon IR3300 no image, no error
    Stop the copy as the paper is underneath the drum, remove the drum, see if there's an image. If yes then you have a transfer roller issue, if no then the dev may not be cammed properly against the drum. If laser failed it would spit out an e100
    • jupiii
      • Apr 2012
      • 9
      And, if you don't have image on drum unit it can be also problem in shutter.
      You have in the upper part of front door one metal plate which is for oppening
      shutter or the laser unit. Maybe is that metal plate broken or plastic part of
      shutter on cover of laser unit is broken.
      • northernlife
        • Sep 2011
        • 847
        PS12 can cause this too.
        • greyrock
          Thank you northernlife and jupiii, I'll check these suggestions tonight and report back. Stay tuned!
