We have an iR-ADV C9075 PRO in the showroom that has had the fuser taken from it for a few clients over last few months.
Intermittently since we have had the machine I have noticed an e009 code would appear. It appeared to go away one day and only recently has it become a real issue.
As of right now the machine will get to ready on boot up, then if you run a copy of any kind (even plain paper) it will typically jam right before it gets to the fuser and then it will throw the e009 code. I have opened a case with CCI regarding this but they are sort of confused by it...
Recently we had a C7065 with a similar problem where we could only fix it by changing the wire harnesses in the fixing tray.
I haven't gotten to this point yet, but I have swapped the entire fuser (this includes the base unit) and the motor at the rear of the fuser that drives the cam for the pressure belt. The error pertains to pressure release timing.
I will be honest when I say I haven't had a ton of time to work on this, but it has been consistent lately and the machine is practically useless.
Anybody have this issue before?
The machine is practially brand new with 16k on it, running latest FW.
Cheers
Cheers
