IR 7105
  • canonguy
    IR 7105
    Quick question i have an IR 7105 does any know if the fixing rollers are the the same as a IR 9070 and is there a fixing QA kit for the 7105 thanks
  • totoro
    • 568
    IR 7105
    FB5-6930-000 ROLLER, FIXING
    FB6-2374-000 ROLLER, PRESSURE
    IR 9070
    FC7-2690-000 ROLLER, PRESSURE
    Don't know about the QA kit
    Totoro
    Totoro
    • alex@wocltd.com
      • 430
      and what about bushings,bearings, thermistors & sub thermistors?.....
      • throttlejockey
        • Mar 2008
        • 17
        you can use the 105 fuser kit. the lwr roller is not the same on the 7105 but you can use the 105 ive seen no diff when using the lwr roller in the kit.
        • mtech
          • Mar 2007
          • 307
          Throttlejockey is correct. I have replaced dozens of 7105 fusers with 105 fixing kits. Never had any issues at all. That is all our techs use.
          • xcopytech
            • Aug 2006
            • 1794
            ir 7200/8500/8070/9070/105/7105 can use same parts for fuser
