canon ir 3035
  • Luther
    • May 2006
    • 682
    canon ir 3035
    Have one in the field that is giving me black copies , replaced the drum(though it might be a bad ground) checked all contacts. during the copy process i get bias but nothing else, do the high voltage units go bad on theses? never had to replace on on any of these series..if so is this the correct part number? fm2-0261-010? thanks..dont have the parts manual
  • Luther
    • May 2006
    • 682
    Re: canon ir 3035
    should have added the error code im getting e064-002....thanks
      Re: canon ir 3035
      Error :
      The machine displays 064-0002. The machine creates solid black copies/internal test prints from edge to edge without any blanking.
      Workaround :
      Check the physical connections of the primary contacts. The primary drum contact is located on the drum and makes contact with an HVT metal contact on the machine's rear. The drum's primary contact tab can be easily bent or deformed during drum replacement or removal. If it becomes bent it can cause solid black copies creating a voltage leak also causing an 064-0002. Before replacing the high voltage power supply check the contact tabs first. Reshape the contacts or replace the drum.
      • Luther
        • May 2006
        • 682
        Re: canon ir 3035
        Thanks for the reply..but i did all that
        • northernlife
          • Sep 2011
          • 847
          Re: canon ir 3035
          Pull out the dev and clean the contacts very well. Replace the trans roller. A paper clip in the dev will cause this code and symptom as well.
          • Luther
            • May 2006
            • 682
            Re: canon ir 3035
            was the high voltage unit
            • northernlife
              • Sep 2011
              • 847
              Re: canon ir 3035
              HV Power supply?
