Canon IPR 6010
  • khaled_abosere3@yahoo.com
    Head technical support
    • Mar 2012
    • 171
    [Error Code] Canon IPR 6010
    First : machine suddenly display error code (E540-8001-02)as in manual that related to finisher and the following message for (Limit Function Mode) appeared so we set it to (on) and error code gone.
    Second : another message with normal LCD appear says (Finisher cannot be used)
    Finaly we needed to use finisher in sorter but pervious message (Finisher cannot be used) does not permit us.
    With my greetings.
    • 16083
    Re: Canon IPR 6010
    With my greetings.
    turn Limited Functions Off and power cycle the copier.
    E540-8001-02
    Tray A rotation detection sensor does not come ON within 300ms after the tray A lifter motor operation begins.
    then
    - Check tray A rotation detection sensor connectors.
    - Check tray A lifter motor connectors.
    - Replace tray A rotation detection sensor.
    - Replace tray A lifter motor.
    • Kalamar
      • May 2014
      • 23
      • kiwitech
        • Oct 2012
        • 29
        Re: Canon IPR 6010
        also check they tray has not been bent down
