Finisher Can not connect ir7095
Re: Finisher Can not connect ir7095
pic too dark/
check of the A/C voltage into the Finisher Power Supply
the supply voltages were checked at the Finisher Controller
LED 108 on the Finisher Controller PCB is not Lit
u mean Finisher Not Recognized
When LED 108 is not lit on the Finisher Controller pcb but all the other LED's are lit properly, check the LCD display on the Control Panel for the message Finisher cannot be used.
If the message Finisher cannot be used is displayed or Ready to Copy (Functions Limited) is on the display, enter Additional Functions, select Common Settings, then scroll to and select Limited Functions Mode. If Finisher Tray A/B is ON change the setting to OFF then press OK. Make sure everything else under Limited Functions Mode is set to OFF, then power the copier and finisher off. Turned the finisher then the copier back on and see if LED 108 on the Finisher Controller comes on and the finisher cycles.
Whenever Finisher Tray A/B is set to ON under Limited Functions Mode, LED 108 on the Finisher Controller pcb will not come on.**Knowledge is time consuming, exhausting and costly for a trained Tech.**
