Canon C5185 - blurred copies
  • kuby
    • Oct 2007
    • 1408
    Have replaced drums, transfer belt, auto-grad, fuser. Still has blurred copies, prints, etc.
    Anyone found a solution for this or had this happen before?
  • teckat
    • 16083
    Re: Canon C5185 - blurred copies
    iRC5185 came out in y2007, blur copies & prints have been an issue since then-there have been numerous pubs posted here from Canon.
    1-u did not say if issue is in Main Scan or Sub-Scan(paper feed) direction ? or a combo of both directions ?
    2-did u check>clean or replace the SALT SENSOR UNIT ?
    3-did u set LASERS to home position ? ( in service mode or manually)
    iRC5180_Color_Shift_Prevention _&_Correction.pdf
    what does the PG6 GRID test print show ?
