An error code E000020-1060 came up on screen after changing all drums (CYMK). Having researched the following were tried without any good results;
1) Laser removed and cleaned including polygon motor - no good
2) New Laser with another ne Ydrum/dev tried - no good
Also at this stage (DMax/D-Half ciontrol) set to zero before inserting new drum. AUTO-DH set to 0 in COPIER-OPTION-IMG-DEV
3) High Voltage PCB assy tried - no good.
However if the old drums are inserted, the MFD works ok.
Could anyone explain why and the resolution to this problem.
Thanking you all.
Thanking you all.
