canon irc2020 remove paper from the output tray
  • dickiebob
    • Sep 2011
    • 66
    Hi
    We have a machine that is asking you to remove paper from the output tray when there is none present.
    The sensor arm is present and functioning correctly.
    If you restart the machine it willl work fine for a few minutes then throw the error again.
    Has anyone had this please?
  • 20 year tech
    • May 2014
    • 577
    Re: canon irc2020 remove paper from the output tray
    does this machine have a inner finisher ? if so check the lower limit switch sensor connection
    • dickiebob
      • Sep 2011
      • 66
      Hi
      Thnks for reply but no inner finisher just basic machine.
      • northernlife
        • Sep 2011
        • 847
        In this case, the message was displayed because PI10 (Lower Limit Sensor) was defective. Replace sensor with (WG8-5696-000).
        • dickiebob
          • Sep 2011
          • 66
          We will try that thank you for replies.
          • northernlife
            • Sep 2011
            • 847
            ignore my post, didn't read the no internal finisher. Are you getting this on the UI for the machine or on the print driver? If driver, reload it with the latest and replace the old drive. If UI then initialize all settings from system settings.
            • dickiebob
              • Sep 2011
              • 66
              It displays the error on the machine display
              • northernlife
                • Sep 2011
                • 847
                initialize the settings and/or clear all. Does the black sensor flag where the paper comes out move freely?
