Let me guess....7105. If so might need laser diode assembly...changed quite a few. If other products make sure primary cover is opening laser shutter. VLm being 170 indicates laser is not discharging light area during potential control
those numbers mean nothing unless u explain what is going on with your copy quality or test prints/
================================================== =============== VL1M =light area potential measurement value (for copier) range: 0 to 600; approx. optimum: VL1T +/-6 V
the value indicated is in relation to the most recent potential control / in your case (170)
Is the reading of <VL1M> between 50 and 90?/
in your case answer is "NO"
Check the following; if faulty, replace it:
1. Laser output The machine determines the optimum laser output so that the drum surface potential (light area potential VL) is identical to the target potential The machine takes measurements multiple times to determine the relationship between the drum surface potential (VL) and the laser output.If the optimum laser output cannot be determined after measuring the drum surface potential, the machine starts its compensatory control sequence to determine the optimum laser output.
2. Potential control system The potential control system is associated with the following control items:
[1] Determination of optimum grid bias (VD control)
[2] Determination of optimum laser output (VL control)
[3] Determination of optimum developing bias (DC; Vdc control)
