iR ADV 2220 fixing film unit Gear
  • Rakesh
    • May 2012
    • 72
    [Misc] iR ADV 2220 fixing film unit Gear
    i am looking to replace this below gear in iR ADV c2220 copier fixing film unit.
    need a part code for this gear.
    please help.
    View Life As A Continuous Learning Experience...
    Re: iR ADV 2220 fixing film unit Gear
    If its in the fuser I don't think its available separately.
    • teckat
      • 16083
      please help.
      [ATTACH=CONFIG]26040[/ATTACH]
      Real Q is what stripped those helical gears
      imageRUNNER ADVANCE C2020 series
      Found this pub. see attach
      Chipped Gear Inside the Fixing Assembly
      <Factory Measure>
      The shapes of the 21T/15T gear and the 35T gear have been changed to increase the engagement area so that the chipping of the gear is reduced.
      In conjunction with this change, the shape of the lower fixing cover has also been changed to protect the new type 21T/15T gear when the Fixing Assembly is installed.
      If the above symptom occurs, replace all three parts - the 21T/15T gear , the 35T gear and the lower fixing cover at the same time.
      COVER, FIXING,LOWER 810
      New RC2-6506-000
      GEAR, 21T/15T
      New RU6-0710-000
      GEAR, 35T
      New RU6-0711-000
      FIXING ASSEMBLY
      FM4-6227-000
      • Rakesh
        • May 2012
        • 72
        Thank you sir.
        • Canuck
          Tech Specialist
          • 1713
          Engineer needs to be bitch slapped....very cheap low grade plastic
          • teckat
            • 16083
