IR Advance 5250 E147
  • misserable old git
    • Aug 2014
    • 19
    [Error Code] IR Advance 5250 E147
    Hi. Has anyone come across E147 on a Adv 52xx? Error occurs halfway through boot process. sorry no more info at the moment, going back tommorow
  • teckat
    • 16083
    Re: IR Advance 5250 E147
    Error Diagnosis.pdf
    Try and run a > Boot System Error Diagnosis
    Boot Method
    1) Turn ON the Main Power Supply Switch while pressing the Control Panel Power Supply
    Switch.
    2) Right after the Main Power Supply Lamp lights up once, it lights out instantly, and diagnosis starts.
    (When the Main Power Supply Lamp lights out, you can release your finger from the Control
    Panel Switch.)
    Diagnosis Time
    Diagnosis is completed in approx. 1 minute.
    <When the diagnosis result is normal>
    After the Main Power Supply Lamp repeatedly lights out 5 times, it lights up and the diagnosis is completed.
    After completion of the diagnosis, this machine executes normal boot sequence.
    <When an error is detected by diagnosis>
    The Main Power Supply Lamp repeats high-speed blinking after completion of a check in
    which an error is detected.
    For example, when an error is detected in Check 2, the Main Power Supply Lamp lights out twice and repeats high-speed blinking (ON/OFF in 0.3 seconds interval).
    When an error is detected, be sure to count the number of times the Main Power Supply Lamp lights out
    *1: When an error is detected, there is a possibility that the Main Power Supply Lamp may not perform high-speed blinking but perform other operation (continuous light-up, light-out). In this case, remove and then install the 2 SDRAMs on the Main Controller PCB 1.
    If the error is not resolved, execute the remedy of the Check No. which is not completed normally. (For details, see “Error Diagnosis”.)
    *2: Although diagnosis time for Check 3, and Check 4 is longer than that of other Checks, it is correct operation.
    *3: When the 2 SDRAMs are not mounted on the Main Controller PCB 1, this diagnosis is not completed. In this case, install the appropriate 2 SDRAMs.
      • Aug 2014
      • 19
      Thanks... I will try that in the morning and post result..... this will be the 1st time i've needed to use the boot diagnostics.
