dotted horizontal thin line on IR7105
  • Henry
    • Dec 2007
    • 18
    Good day, any idea what causes the dotted horizontal thin line on IR7105 during copying and printing? I already did the following tasks:
    1. replaced all corona wires
    2. cleaned platen glass and white plate
    3. replaced cleaning blade
    4. cleaned developing assembly
    5. and cleaned dust-blocking glass
    It also appears even when copying blank pages and the line doesn't stays in single location, it move along the horizontal lines. Please see the attached scanned sample.
  • vigour
    • Aug 2010
    • 1038
    Re: dotted horizontal thin line on IR7105
    I would say your drum has a problem
    • Henry
      • Dec 2007
      • 18
      does it mean that the drum needs replacement or polishing? The total copies are around 3.9M.
      • misserable old git
        • Aug 2014
        • 19
        try taking drum out and polishing with metal polish, and look out for corresponding marks.
        Could be laser, but not so likely
        • Canuck
          Tech Specialist
          • 1713
          Check star-wheels at fuser entrance guide, lint or something hanging down into laser light path, or possible drum sep claw
          • Rachid.Akli
            • Oct 2011
            • 595
            Hello,
            Print a blank A3 page and verify if there are repeating "same" dots. If yes, roll up the A3 and make these dots coincide. If the result is corresponding to the drum size, clean it or replace it.
            If the primary corona is overused, it emits sparks on the drum surface and leads to this result.
            Rachid.
            "Find a job you love and you’ll never have to work a day in your life." Nagy's father
            • Canuck
              Tech Specialist
              • 1713
              Usually primary arcing on these machines give you deletions....light areas. Machines like 5000,5570,6075,in which laser discharges white area, its is common to see spots from primary arcing. The old NP6050s would get spots from pre-transfer arcing(AC). Crash a copy on the transport belts to see if it is fuser star wheel issue or not. The line is fairly straight
              • Henry
                • Dec 2007
                • 18
                Good day,
                After polishing and inspections the line is still their. Drum is still in verygood condition and copies are excellent. Any suggestions or ideas what to do next?
                • Canuck
                  Tech Specialist
                  • 1713
                  17 posts and you have a rep power of 14? Amazing....lol. Did you crash it on the belts to see if its coming from imaging area?
                  • eliaso
                    • Jul 2014
                    • 52
                    try to clean the charge corona unit again
                    This only have I found:
                    God created mankind upright,
                    but they have gone in search of many schemes.
                    • blazebusiness
                      SanDiegoCopierRepair.com
                      • 1257
                      Agree, most likely a charge corona issue. If rebuilding the corona doesn't fix it. Replace the Corona assy. Canon# FG6-7313-040,
                      • Henry
                        • Dec 2007
                        • 18
                        Good day,
                        Done with the issue by replacing with new Photosensitive Drum, About halfway of the circumference of the drum showed visible dotted lines when using magnifying glass. Not sure what causes this phenomenon. Thanks for all your help and time.
