Canon ImageRunner 400s
  • y83883
    • May 2025
    One of my copiers displays error code E0005, which is to change the fuser cleaning roller. Does anybody know how to change a fuser cleaning roller? Could i do it or should have a vendor come change it?
  • kwazimoto
    • Jan 2007
    • 199
    it would be best to have someone come in so they can look over the fuser ect...
    • totoro
      • 568
      Compared to the newer Canons, this machine is a pain to change the web. You have to pull the fuser out of the lhs of the copier unlike the 5K series and above that just slide out to you. If you have a service manual it can be done, but if you've never done it or seen it done then call someone who knows how.
      Good luck.
      Totoro
      Totoro
      • rajeshkumarind
        • 12
        use service mode press >counter
        clear the misc >web press the >clear
        • y83883
          Default Service code
          Does anyone know what the default service code number is?
          • xcopytech
            • Aug 2006
            • 1783
            Why you do not call a tech to fix your copier?
            • AndrewQOI
              if you just clear the counter and not change the web... you can destroy your fuser... I fuser rebuilt on that model is alot of money.
              If you change the cleaning web yourself, and put it on reverse (which is easy to do) that will also destroy your fuser roller.
              This is best left to a technician. It would be MUCH cheaper than destroying your fixing assembly.
              • shari400
                it is better to call a tech
