How to install Canon iR ADV c5030 on Ubuntu 12.04
  • Rakesh
    • May 2012
    • 72
    [Misc] How to install Canon iR ADV c5030 on Ubuntu 12.04
    Hi, Can someone please guide me to install Canon iR ADV c5030 on Ubuntu 12.04 LTS (64bit)
    need step by step guide. please help.
    I've downloaded file from canon web site.
    http://support-asia.canon-asia.com/contents/ASIA/EN/0100270810.html#r=s&r=s
    View Life As A Continuous Learning Experience...
    Re: How to install Canon iR ADV c5030 on Ubuntu 12.04
    Why..
    many years ago when I dabbled with Linux it was all command line
    tar -xvzf filename.tar.gz
    ./configure
    make
    sudo make install
    Doesn't Ubuntu have some graphical package installer ?
    • teckat
      • 16083
      To install these Canon printer driver for Ubuntu you need to add the PPA below in your Ubuntu system. Open a "terminal" window and copy and paste these commands:
      sudo add-apt-repository ppa:michael-gruz/canon
      sudo apt-get update
      Make sure to disconnect the Canon printer from your computer first.
      Now copy and paste your appropriate install command based on your printer:
      (this might work)
      sudo apt-get install cnijfilter-iRADVC5000series
      After the Canon printer driver is installed, connect the Canon printer to your computer and turn it on. Your printer will automatically be detected by the system.
      • northernlife
        • Sep 2011
        • 847
        um, cups comes with all canon drivers except the presses. sudo apt-get install cups then run the cups config.
