Canon IR 3300 hanged
  • Mohammedirfan
    • Oct 2013
    • 12
    [Misc] Canon IR 3300 hanged
    Hi my canon ir 3300 showing Error E0000-000 i replace the fixing assembly then i try to clear the error but keys are not working just showing error E00000-000, it seems that is hanged the machine. please help me.
  • teckat
    • 16083
    Re: Canon IR 3300 hanged
    Originally posted by Mohammedirfan
    Hi my canon ir 3300 showing Error E0000-000 i replace the fixing assembly the i try to clear the error but keys are not working just showing error E00000-000, it seems that is hanged the machine. please help me.
    check for a stuck key on panel
    check front cover switch SW3 condition ?
    power off>open front door>power on to see if message to close front door shows on panel !!!
    • Mohammedirfan
      • Oct 2013
      • 12
      Ya, i try this but no massage to close front door. it is showing only E0000-000 error.
      • teckat
        • 16083
        chek the wiring harness between J136 on the Composite Power supply and J301 on the DC Controller.
        Check the harness for continuity and pinched wires. Remove tie wraps as necessary.
